Troi releases Troi Dialog Plug-in 13 for FileMaker Pro 26
New FileMaker 26 compatible version automatically grows the buttons for large text
Lienden, the Netherlands, October 28, 2026–Troi today announced the immediate availability of Troi Dialog Plug-in 13.0 for Claris FileMaker Pro 26.
Troi Dialog Plug-in is a very powerful tool for displaying all sorts of dialogs in FileMaker Pro. The text of the dialog and of the buttons can be created dynamically by using a script step or a calculation. All from within FileMaker you can:
  • show an input dialog to let a user input data in up to 20 fields and up to 4 buttons
  • choose these input fields to be any of the following: simple text, password field, popup list or check box
  • show a list dialog or very big text dialog
  • show temporary flash screens
  • show a progress bar for lengthy operations
  • schedule the display of notifications
What is new in version 13?
Improved compatibility:
  • Tested and made compatible with Claris FileMaker Pro 2026 (FileMaker Pro 26).
  • Improved compatibility with Claris FileMaker Pro 2025 (FileMaker Pro 22.0.7).
  • Tested and made compatible with macOS 27 (Golden Gate).
  • Tested and made compatible with Windows 11, including Windows 11 version 26H2 (September 29, 2026).
New functionality:
Furthermore we improved security, made several small bug fixes and improved the overall reliability of the plug-in.
A fully functional demo version of Troi Dialog Plug-in 13 is available on the Dialog Plug-in page.
Licenses cost US$ 79 per user. Details on developer licenses and multi-user discounts can be found on the Dialog Plug-in page. You can order licenses there or from our shop.
Version 13 needs a new registration string. If you bought a license on or after October 1, 2025 the upgrade is FREE! Eligible users will be sent a new v13 registration code. Contact us if you have not received yours after October 31, 2026.
Upgrades from licenses bought before October 1, 2025 are available from US$ 45 per user. Upgrade prices for other licenses can be found in the shop. You can order upgrades there.
Screenshot of Input Dialog run with Troi Dialog Plug-in 13 for FileMaker Pro 26, which automatically shows wider buttons.
Screenshot of a dialog created with Troi Dialog Plug-in 13. The plug-in now automatically makes buttons wider for longer texts.
