[ANN] Troi Encryptor Plug-in 2.0.1 for FileMaker Pro 7
Troi Automatisering releases Troi Encryptor Plug-in 2.0.1 for FileMaker Pro 7
Successor to Troi Coding Plug-in offers industry strength encryption and is compatible with FileMaker 7.
Alphen aan den Rijn, The Netherlands, March 21st, 2005--Troi Automatisering today announced the immediate availability of the final version of Troi Encryptor Plug-in for FileMaker Pro 7.
What is Troi Encryptor Plug-in?
Troi Encryptor Plug-in is a very powerful tool for for securing your FileMaker data, exporting or emailing your data without risk and importing safely back into FileMaker.
All from within FileMaker you can:
- encrypt text or container fields, using the powerful 128 bit Rijndael AES encryption scheme, so that your sensitive data is secure
- export encrypted data that can be sent safely over the Internet, for example via email. No risk that someone will read or change the data while in transit
- use the decryption functions to restore the original information after you have imported the received email or export file back into FileMaker, with the assurance that nobody will have tampered with it
- verify data integrity and sources with MD5 or SHA-1 message digests
- encode text in Base64
- make conversions to and from binary
- compress databases with large text fields
Peter Baanen, company president, states: "We are happy to bring you the final version of the Encryptor with the start of spring (on the Northern hemisphere at least). This plug-in now meets international encryption standards, offering users who need to comply with strict security guidelines the possibility to encrypt their sensitive data within their FileMaker databases."
What is new in version 2.0.1?
No mayor bugs were found in the beta, so in the final version only very minor things are changed. Compared to Troi Coding Plug-in, Troi Encryptor Plug-in 2.0.1 adds these new functions and features:
- industry strength encryption, using the 128 bit Rijndael AES Encryption scheme
- encryption and decryption of container fields, with for example JPEGs in them
- possibility to create MD5 or SHA-11 message digests
- converted to the new External Function API of FileMaker Pro 7
- the plug-in functions now have a size limit of 1 Gb per parameter (up from the - total of 64000 character limit for all parameters in FileMaker 6!)
- each function now supports Unicode characters
Troi Encryptor Plug-in 2.0.1 is compatible with Troi Coding Plug-in 1.6 for FileMaker Pro 6. This means that texts encrypted with Troi Coding Plug-in 1.6 in FileMaker 6, can be decrypted using Troi Encryptor Plug-in in FileMaker 7.
Suggested Uses
- secure your FileMaker data, making sure information can only be read or seen by the people you want
- share medical data over the Internet, including pictures
- enables you to comply with HIPAA guidelines.
- verify the correctness of important text
- compress large texts
A fully functional demo version of Troi Encryptor Plug-in 2.0.1 is available for downloading at Troi's web site at: .
Troi Encryptor Plug-in 2.0.1 works with FileMaker Pro 7. The plug-in is available for Mac OS X 10.2.8 or higher and Windows 2000 (Service Pack 6) or Windows XP.
Troi still offers Troi Coding Plug-in 1.6.2. This version makes use of the 'classic' plug-in API and runs on FileMaker 6 and 5.x. Troi Coding Plug-in is available for Mac OS 9.1 or later, including Mac OS X (10.1.5 or later), and for Windows 2000 (Service Pack 4), or Windows XP. The plug-in should also run without problems on any machine that is able to run FileMaker Pro 4.0, FileMaker Pro 4.1 and runtimes from FileMaker Developer Edition 4.0 and later.
Licenses cost US$ 79 per user. Details on developer licenses and multi-user discounts can be found on our web site. You can order licenses from our web site.
The upgrade is free for all users of Troi Coding Plug-in version 1.6 who bought their license on or after February 1st, 2004. Eligible users have been sent a new registration string. Please contact us if you have not received it.
Users who bought a license for Troi Coding Plug-in version 1.6 or earlier before February 1st, 2004 will need to upgrade to use the 2.0.1 version. Upgrading from a single user license is $29 per user. Upgrade prices for other licenses can be found on our web site. You can order upgrades from our web site.
AutoUpdate example now includes Troi Encryptor
We posted a new example file on our web site, showing how to use the AutoUpdate feature of FileMaker Server 7 with the Troi FileMaker 7 Native plug-ins. On the AutoUpdate page we have also included .tar formatted files of Troi Encryptor Plug-in, Troi File Plug-in and Troi Text Plug-in, making it easier to implement AutoUpdate on Mac OS X.
The example file and the .tar formatted files are available for downloading at Troi's web site at: .
Diana Budding,
Vuurlaan 18
Telephone: +31-172-426606
Fax: +31-172-470539
