[ANN] Troi Dialog Plug-in 4.0 for FileMaker Pro 7
FOR IMMEDIATE RELEASE:
Troi Automatisering releases Troi Dialog Plug-in 4.0 for FileMaker Pro 7
New FileMaker Pro 7 plug-in brings custom Unicode dialogs.
Alphen aan den Rijn, The Netherlands, May 24th, 2005--Troi Automatisering today announced the immediate availability of Troi Dialog Plug-in 4.0 for FileMaker Pro 7. Troi Dialog Plug-in 4.0 makes use of the extended plug-in API of FileMaker 7. Calls to the plug-in's functions can now support Unicode and more and bigger parameters.
At the same time Troi is releasing Troi Dialog Plug-in 3.6. This version makes use of the 'classic' plug-in API. Users that upgrade to FileMaker 7 but also want to use the Dialog Plug-in on earlier versions of FileMaker Pro can use this version. The 3.6 version runs on FileMaker 6 and 5.x.
Troi Dialog Plug-in is a very powerful tool for displaying all sorts of dialogs in FileMaker Pro 7. The text of the dialog and of the buttons can be created dynamically by using a calculation. All from within FileMaker you can:
- show dialogs with variable text and up to 4 buttons
- show an input dialog to let a user input data in up to 9 fields
- show a list dialog or big text dialog
- position the dialog box anywhere on the screen
- add a standard icon or your own icons
Peter Baanen, company president, states: "I'm very excited that this plug-in is finally native for FileMaker Pro 7. With the plug-in supporting Unicode international deployment, for example to Japan, is even easier!"
What is new in version 4.0?
Troi Dialog Plug-in 4.0 is completely rewritten for FileMaker 7. This release adds these new features:
- Converted to the new External Function API of FileMaker Pro 7.
- The plug-in functions now have a size limit of 1 Gb per parameter (up from the total of 64000 character limit for all parameters in FileMaker 6!)
- The function parameters now support Unicode characters (Some dialogs only support ASCII at the moment.)
Suggested Uses
- create a small list dialog when you have only a little list and a big one if you have a big list
Fully functional demo versions of Troi Dialog Plug-in 4.0 and Troi Dialog Plug-in 3.6 are available for downloading at Troi's web site at: .
Troi Dialog Plug-in 4.0 works with FileMaker Pro 7. The plug-in also can be used with runtimes from FileMaker Developer 7. The plug-in is available for Mac OS X 10.2.8 or higher and Windows 2000 (Service Pack 6) or Windows XP.
Troi Dialog Plug-in 3.6 works with FileMaker Pro 7 and FileMaker Pro 6. The plug-in is available for Mac OS version 9.1 through Mac OS 9.2.2, Mac OS X 10.2 or higher and Windows 2000 or Windows XP.
Licenses cost US$ 49 per user. The registration you receive after paying the license fee will work with version 4.0 as well as with version 3.6! Details on developer licenses and multi-user discounts can be found on our web site. You can order licenses from our web site.
Note: If you just want to use the 3.6 version, note that version 3.6 also accepts older 3.5 registrations.
Product updates from version 3.5.1 and later, bought on or after March 1st, 2004, are FREE: eligible users will be sent a new registration string in the next few days. Upgrades from version 3.5.1 or earlier, bought before March 1st, 2004, are available from US$ 19 per user.
Upgrade prices for other licenses can be found on our web site. You can order upgrades from our web site.
Diana Budding,
Vuurlaan 18
Telephone: +31-172-426606
Fax: +31-172-470539
Kijk al uit naar de update van de Serial plugin :?: En tipje;heb Peter vroeger daarover al eens gemaild ; reactietijd van scripttrigger mag sneller :)
Maar is een geweldig produkt dat zonder problemen veel hardware stuurd :!:
