[ANN] Troi Dialog Plug-in 5.5.4 for FileMaker Pro 11
Troi Automatisering releases Troi Dialog Plug-in 5.5.4 for FileMaker Pro 11
Troi Dialog Plug-in updated for FileMaker Pro 11.
Alphen aan den Rijn, The Netherlands, October 11th, 2011--Troi Automatisering today announced the immediate availability of Troi Dialog Plug-in 5.5.4 for FileMaker Pro 11.
Troi Dialog Plug-in is a very powerful tool for displaying all sorts of dialogs in FileMaker Pro 11. The text of the dialog and of the buttons can be created dynamically by using a calculation. All from within FileMaker you can:
- show an input dialog to let a user input data in up to 15 fields and up to 4 buttons
- show a list dialog or very big text dialog
- add a standard icon or your own custom icons, now also with transparent PNGs
- present a slideshow of images and movies fullscreen
What is new in version 5.5.4?
Troi Dialog Plug-in 5.5.4 is a maintenance release, but also adds a few enhancements:
- Improved the Dial_ProgressBar function: you can now press the ESC key to stop the dialog, by adding the switch: "-StopOnESC".
- (Mac OS X) Improved the the Dial_Dialog function, so that the title is now visible. Note that this change only occurs in FileMaker Pro 11.
- Added a switch "-TitlesInProgressBarDialogs" to the Dial_SetPreference function. When you set this to "off" the ProgressBar title is set to blank for all subsequent calls of the ProgressBar dialog.
- (Mac OS X) Fixed a bug in the Dial_Dialog function when running FileMaker Pro 11, where after typing several characters they would end up in the FileMaker file under the dialog.
- Fixed a bug in the Dial_ProgressBar function, with the handling of blocking alert dialogs that can appear below the ProgressBar Dialog.
- Fixed a bug with the Dial_InputDialog function and FileMaker Pro 9 where copy and paste did not work.
- Updated User Guide and Overview.fp7 to reflect the added functionality.
Suggested uses
- show a slideshow of images selected from a found set, for example all images with water as a keyword
- measure time like for a race or the efficiency of 2 differently implemented scripts.
All these features also work in a runtime solution. We invite you to test drive the new functions and see what you can do with it!
Pricing & availability
A fully functional demo version of Troi Dialog Plug-in 5.5.4 is available for downloading at Troi's web site at:
Troi Dialog Plug-in 5.5.4 works with FileMaker Pro 9, 10 and 11. The plug-in can also be used with runtimes from FileMaker Pro Advanced 9, 10 or FileMaker Pro Advanced 11. The plug-in is available for Mac OS X and Windows.
On Mac OS X the plug-in runs in Mac OS X 10.5.7 or higher (including Mac OS X 10.6 and OS X 10.7 Lion). The plug-in also runs on Windows Vista or Windows 7. QuickTime 7 or later is needed for the Dial_PresentImage() function.
Licenses cost US$ 59 per user. Details on developer licenses and multi-user packs can be found on our web site. You can order licenses from our web site.
Upgrading to version 5.5.4 is free for all users of version 5.5.x. Troi Dialog Plug-in v5.5.4 works with the same 5.5 registration string.
Users who bought a license for Troi Dialog Plug-in on or after February 1st, 2008 are still entitled to a free upgrade. We have emailed these registered users a new registration string in March 2010.
Upgrades from licenses bought before February 1st, 2008 are available from US$ 29 per user. You can order upgrades from our web site.
D. Budding
