[ANN] Troi Activator Plug-in 4.5.1 for FileMaker Pro 16
Updated script triggering plug-in for FileMaker Pro 16 improves stability.
Alphen aan den Rijn, the Netherlands, December 11, 2017–Troi today announced the immediate availability of Troi Activator Plug-in 4.5.1 for FileMaker Pro 16.
What is Troi Activator Plug-in?
Troi Activator Plug-in is a very powerful tool for triggering scripts remotely. All from within FileMaker you can:
- trigger a FileMaker script on a different computer (remotely)
- trigger a FileMaker script over internet
- use the built-in security to prevent unauthorized triggering
- send a number (e.g. a record ID) and a long text with the trigger
- start and stop listening for remote trigger messages with one script step
- communicate with databases in different FileMaker versions or even runtimes
Except from remote triggering you can also use the Activator Plug-in for:
- triggering a script on a specified date and time
- scheduling events which trigger any script you want
- running a script from any FileMaker calculation, for example a tooltip calculation
- validating fields on exiting a record with a custom script suited to your specific needs
What is new in version 4.5.1?
Troi Activator Plug-in 4.5.1 is a maintenance release and has the following fixes and improvements:
- (Mac OS) Fixed a crashing problem with installing or disabling the plug-in: FileMaker Pro no longer crashes when disabling the plug-in. Note: if you have installed version 4.5 you need to remove the plug-in manually to avoid the crashing. You will find instructions how to manually update Troi Activator Plug-in 4.5 here: https://www.troi.com/additional/manually-update-troi-activator-plugin-instructions/
- (Mac OS) Fixed a compilation problem with code signing and extended attributes in Mac OS 10.12 (Sierra).
- Improved type-ahead of external function names.
A fully functional demo version of Troi Activator Plug-in 4.5.1 is available for downloading at https://www.troi.com/products/activatorplugin/
Licenses cost US$ 89 per user. Details on developer licenses and multi-user discounts can be found on our web site. You can order licenses from our web site.
The 4.5.1 version works with the 4.5 version of the registration. If you bought a license for a pre-4.5 version on or after June 14, 2016 the upgrade is FREE! Eligible users have been sent a new registration string in September 2017.
Upgrades from licenses bought before June 14, 2016 are available from US$ 39 per user. Upgrade prices for other licenses can be found on our web site.You can order upgrades from our web site.
End of year sale: all licenses 10% off!
Until the end of 2017 we offer a 10% discount on all Troi plug-in licenses! Order your new licenses and upgrades for any of the Troi plug-ins from https://www.troi.com/shop/ and enter the following coupon code upon checkout:
END2017SALE
The coupon code is valid until December 31, 2017.
