Troi releases Troi Dialog Plug-in 10.0 for Claris FileMaker Pro 19.3
New FileMaker 19.3 compatible version runs native on Apple Silicon
Lienden, the Netherlands, June 24, 2021–Troi today announced the immediate availability of Troi Dialog Plug-in 10.0 for Claris FileMaker Pro 19.3.
Troi Dialog Plug-in is a very powerful tool for displaying all sorts of dialogs in FileMaker Pro. The text of the dialog and of the buttons can be created dynamically by using a script step or a calculation. All from within FileMaker you can:
  • show an input dialog to let a user input data in up to 20 fields and up to 4 buttons
  • choose these input fields to be any of the following: simple text, password field, popup list or check box
  • show a list dialog or very big text dialog
  • show temporary flash screens
  • show a progress bar for lengthy operations
  • add a standard icon or your own custom icons
What is new in version 10.0?
Troi Dialog Plug-in 10 has been rewritten to improve its compatibility:
  • Tested and made compatible with Claris FileMaker Pro 19.3.
  • (macOS) The plug-in now runs natively on Apple Silicon: made the plug-in a Universal binary by adding code for the arm64 architecture of macOS.
  • Tested and made compatible with macOS 11.4 (Big Sur).
  • Tested and made compatible with Windows 10 version 20H2 (October 2020 Update) and version 21H1 (May 2021 Update).
  • Updated the plug-in to use the latest libraries or modern frameworks where possible.
  • Updated the example files to beter handle newer plug-in versions.
A fully functional demo version of Troi Dialog Plug-in 10.0 is available on the Dialog Plug-in page.
Licenses cost US$ 59 per user. Details on developer licenses and multi-user discounts can be found on the Dialog Plug-in page. You can order licenses there or from our shop.
Version 10.0 needs a new registration. The upgrade is free for users who bought a license for Troi Dialog Plug-in on or after November 10, 2020. Eligible users have been sent a new registration. Contact us if you have not received yours.
Upgrades from licenses bought before November 10, 2020 are available from US$ 35 per user. Upgrade prices for other licenses can be found in the shop. You can order upgrades there.
Troi Dialog Plug-in 10 for FileMaker Pro 19.3: native on Apple Silicon!
