[ANN] Troi Dialog Plug-in 4.5 for FileMaker Pro 8.5
Troi Automatisering releases Troi Dialog Plug-in 4.5 for FileMaker Pro 8.5
New Universal and cross platform plug-in runs natively in FileMaker Pro 8.5 and lets you create powerful custom dialogs.
Alphen aan den Rijn, The Netherlands, July 18th, 2006--Troi Automatisering today announced the immediate availability of Troi Dialog Plug-in 4.5 for FileMaker Pro 8.5
Troi Dialog Plug-in is a very powerful tool for displaying all sorts of dialogs in FileMaker Pro 8.5. The text of the dialog and of the buttons can be created dynamically by using a calculation. All from within FileMaker you can:
- show dialogs with variable text and up to 4 buttons
- show an input dialog to let a user input data in up to 9 fields
- show a list dialog or big text dialog
- position the dialog box anywhere on the screen
- add a standard icon or your own icons
Peter Baanen, company president, states: "Just a week after the launch of FileMaker 8.5, I'm happy to present you our third plug-in which is ready for FileMaker Pro 8.5. This plug-in runs natively in FileMaker 8.5 and is also a Universal Plug-in on Mac."
What is new in version 4.5?
Troi Dialog Plug-in 4.5 has been recompiled to run with FileMaker 8.5. This release adds these new features:
- Made compatible with FileMaker Pro 8.5.
- (Mac OS X) Converted to Universal plug-in which runs natively on PowerPC and Intel Macs.
- The list of Dialog functions is now also visible when creating custom functions.
- Added a consistency check for missing resources.
- Fixed several bugs, specifically in the Dial_BigInputDialog function.
- Cleaned up example files and specifically the ListDlog.fp7 and All Dialog Examples.fp7 example file.
Suggested Uses
- create a small list dialog when you have only a little list and a big one if you have a big list
All these features also work in a runtime solution. We invite you to test drive the new
functions and see what you can do with it!
A fully functional demo version of Troi Dialog Plug-in 4.5 is available for downloading at Troi's web site at:
Troi Dialog Plug-in 4.5 works with FileMaker Pro 7, 8 and 8.5. The plug-in can also be used with runtimes from FileMaker Developer 7, FileMaker Advanced 8 or FileMaker Advanced 8.5. The plug-in is available for Mac OS X and Windows.
On Mac OS X the plug-in runs in Mac OS X 10.3.9 or higher for PowerPC-based Macs and Mac OS X 10.4.5 or higher for Intel-based Macs. The plug-in also runs on Windows 2000 (Service Pack 4) or Windows XP (Service Pack 2).
Licenses cost US$ 49 per user. Details on developer licenses and multi-user discounts can be found on our web site. You can order licenses from our web site.
Product updates from earlier versions, bought on or after March 1st, 2005, are FREE: eligible users will be sent a new registration string. Contact us if you have not received yours after July 22nd, 2006.
Upgrades from licenses bought before March 1st, 2005, are available from US$ 19 per user.
Upgrade prices for other licenses can be found on our web site. You can order upgrades from our web site.
Running plug-ins on FileMaker Pro 8.5 and Intel Macs
FileMaker Pro 8.5 for Mac OS X is a Universal Application and can run natively on PowerPC and Intel Macintoshes. However, when FileMaker is launched on Intel Macs, it only loads Universal plug-ins. It does not load PowerPC plug-ins. Therefore all plug-ins need to be converted to Universal plug-ins. Troi has already been preparing for these new Universal versions and we expect to release more Universal versions of our other plug-ins soon.
You can find more information on this on our FileMaker Pro 8.5 compatibility page:
Troi Automatisering is leading developer of cross platform FileMaker Pro plug-ins. For more information, visit our web site at:
Diana Budding
Vuurlaan 18
Telephone: +31-172-426606
Fax: +31-172-470539
