Diana Budding Posted July 25, 2006 Posted July 25, 2006 Troi releases two updated plug-ins for FileMaker Pro 8.5 Today we released an update and a beta. First we released an updated version of Troi File Plug-in (3.5.1). Secondly we released a new version of Troi URL Plug-in 2.0b1 (beta). Troi File Plug-in 3.5.1 for FileMaker Pro 8.5 This Universal and cross platform plug-in runs natively in FileMaker Pro 8.5 and lets you manipulate your files and folders directly from your databases. Troi File Plug-in 3.5.1 is a minor update. It fixes a bug that prevented the plug-in from loading with FileMaker Pro 7. It also features an updated user guide for version 3.5. If you run FileMaker 7 this update is required, for others updating is recommended. More details and a fully functional demo version of Troi File Plug-in 3.5.1 is available for downloading at Troi's Web site at: . Troi URL Plug-in 2.0b1 for FileMaker Pro 8.5 New beta plug-in for FileMaker Pro 8.5 lets you get and post data and retrieve images from the Internet. July 24th, 2006, Alphen aan den Rijn, The Netherlands--Troi Automatisering today announced the availability of Troi URL Plug-in 2.0b1 for FileMaker Pro 8.5. What is Troi URL Plug-in? Troi URL Plug-in can help you fill in forms on the Internet, all from FileMaker Pro. It also retrieves data or images from any HTTP URL. You can: - use the POST command to fill in a web form and retrieve the result directly in FileMaker - use the GET command to retrieve data - use a secure connection (HTTPS) using SSL - get access to password protected web pages - encode text into HTTP format - get JPEG and also GIF images directly into a container field - send cookies with a request - show a custom progress dialog during the retrieval (Mac OS only) Suggested Uses Troi URL plug-in allows you to: - fill in forms on web sites or your intranet - get online data like stock quotes, weather reports, etc. - automatically add information to listings and online databases - search the Internet for terms or other specific items - get the time of your city All these features also work in a runtime solution. What is new in Troi URL Plug-in 2.0b1? Troi URL Plug-in 2.0b1 adds these new functions and features: - Made compatible with FileMaker Pro 8.5. - (Mac OS X) Converted to Universal plug-in which runs natively on PowerPC and Intel Macs. - Added "-ExtraImageCheck" switch to the TURL_Get and TURL_Post functions. This will make the plug-in do extra checking on the returned data if the data might be an image after all even if the image on the web site doesn't have a .png or .gif extension. - Added new function: TURL_GetLastProperties, to retrieve the last image properties: image type, image height and width. - Added switch -ReturnDataAfterError to TURL_Get and TURL_Post functions. This will return the error code followed by the data. Useful for debugging when partial data is returned. - The plug-in now recovers better from some errors in the TURL_Get and TURL_Post functions. - Improved file type checking for images, especially GIFs, in the TURL_Get and TURL_Post functions. - Added sanity checks to the TURL_Get and TURL_Post functions. The plug-in now checks if returned images are corrupt or invalid. If this is the case error $$-4247 is returned. This can prevent FileMaker from hanging on the invalid image. - Fixed some bugs. This plug-in complements the web viewer to get all sorts of data from the Internet. We invite you to test drive the new functions and see what you can do with it! Pricing & Availability A fully functional demo version of Troi URL Plug-in 2.0b1 is available for downloading at Troi's Web site at: . Troi URL Plug-in 2.0b1 works with FileMaker Pro 7, 8 and 8.5. The plug-in can also be used with runtimes created by FileMaker Developer 7 or by FileMaker Advanced 8 or FileMaker Advanced 8.5. The plug-in is available for Mac OS X 10.3.9 or higher (on PowerPC), for Mac OS X 10.4.5 or higher (Intel-based Mac) and Windows XP (Service pack 2). Licenses cost US$ 59 per user. Details on developer licenses and multi-user discounts can be found on our web site. You can order licenses from our web site. Upgrade information Product updates from earlier versions, bought on or after March 1st, 2005, are free: eligible users will be sent a new registration string. Contact us if you have not received yours after July 30th, 2006. Upgrades from licenses bought before March 1st, 2005, are available from US$ 19 per user. Upgrade prices for other licenses can be found on our web site. You can order upgrades from our web site. Running plug-ins on FileMaker Pro 8.5 and Intel Macs FileMaker Pro 8.5 for Mac OS X is a Universal Application and can run natively on PowerPC and Intel Macintoshes. However, when FileMaker is launched on Intel Macs, it only loads Universal plug-ins. It does not load PowerPC plug-ins. Therefore all plug-ins need to be converted to Universal plug-ins. Troi has already been preparing for these new Universal versions and we expect to release more Universal versions of our other plug-ins soon. You can find more information on this on our FileMaker Pro 8.5 compatibility page: . About Troi Automatisering Troi Automatisering is leading developer of cross platform FileMaker Pro plug-ins. For more information, visit our web site at: . Contact information Diana Budding Troi Automatisering Vuurlaan 18 2408 NB Alphen aan den Rijn, The Netherlands Telephone: +31-172-426606 Fax: +31-172-470539 Newsroom: Quote
