Diana Budding Geplaatst: 26 september 2007 Geplaatst: 26 september 2007 Troi Automatisering releases Troi Encryptor Plug-in 2.5.2 for FileMaker Pro 9 Updated plug-in for FileMaker Pro 9 offers industry strength encryption and decryption of data and images. September 25th, 2007, Alphen aan den Rijn, The Netherlands--Troi Automatisering today announced the availability of Troi Encryptor Plug-in 2.5.2 for FileMaker Pro 9. What is Troi Encryptor Plug-in? Troi Encryptor Plug-in is a very powerful tool for for securing your FileMaker data, exporting or emailing your data without risk and importing safely back into FileMaker. All from within FileMaker you can: - encrypt text or container fields, using the powerful 128 bit Rijndael AES encryption scheme, so that your sensitive data is secure - export encrypted data that can be sent safely over the Internet, for example via email. No risk that someone will read or change the data while in transit - use the decryption functions to restore the original information after you have imported the received email or export file back into FileMaker, with the assurance that nobody will have tampered with it - verify data integrity and sources with MD5 or SHA-1 message digests - encode text in Base64 - make conversions to and from binary - compress databases with large text fields Suggested Uses - secure your FileMaker data, making sure information can only be read or seen by the people you want - share medical data over the Internet, including pictures - comply with HIPAA guidelines - verify the correctness of important text - compress large texts All these features also work in a runtime solution. What is new in version 2.5.2? Troi Encryptor Plug-in 2.5.2 is mainly a bug fix release. Here are the changes: - Added compatibility with FileMaker Pro 9. - Added compatibility with Windows Vista. - Fixed a bug in the Encr_DecodeBase64 function, where the last Base64 character would not always be decoded correctly. - Added new switch "-DecodeSafeAsciiDecryptDESDecompress" to the Encr_Code() function. This will perform three actions in succession: first decode from SafeAscii, then decrypt the intermediate result (using decryptDES) and finally decompress it. - Fixed a small inconsistency with Encr_Version( "-GetVersionString" ). - Updated the User Guide and examples for version 2.5.2. We invite you to test drive the new functions and see what you can do with it! Pricing & Availability A fully functional demo version of Troi Encryptor Plug-in 2.5.2 is available for downloading at Troi's Web site at: . Troi Encryptor Plug-in 2.5.2 works with FileMaker Pro 7, 8.x and 9. The plug-in can also be used with runtimes created by FileMaker Developer 7 or by FileMaker Pro Advanced 8.x or FileMaker Advanced 9. The plug-in is available for Mac OS X 10.3.9 or higher (on PowerPC), for Mac OS X 10.4.5 or higher (Intel-based Mac) and Windows XP (Service pack 2) and Windows Vista. Licenses cost US$ 79 per user. Details on developer licenses and multi-user discounts can be found on our web site. You can order licenses from our web site. Upgrade information Product updates from earlier versions, bought on or after February 15th, 2005, are free: eligible users have been emailed a new registration string last year. Contact us if you have not received yours. Upgrades from licenses bought before February 15th, 2005, are available from US$ 29 per user. Upgrade prices for other licenses can be found on our web site. You can order upgrades from our web site. About Troi Automatisering Troi Automatisering is leading developer of cross platform FileMaker Pro plug-ins and winner of the FileMaker Pro Excellence Award 2001. For more information, visit our web site at: . Contact information D. Budding Troi Automatisering Vuurlaan 18 2408 NB Alphen aan den Rijn, The Netherlands Telephone: +31-172-426606 Newsroom: Quote
