Diana Budding Geplaatst: 10 maart 2010 Delen Geplaatst: 10 maart 2010 Troi Automatisering releases Troi Dialog Plug-in 5.5 for FileMaker Pro 11 Updated dialog plug-in for FileMaker Pro 11 adds creating custom transparent icons from PNG images. Alphen aan den Rijn, The Netherlands, March 10th, 2010--Troi Automatisering today announced the immediate availability of Troi Dialog Plug-in 5.5 for FileMaker Pro 11. What is Troi Dialog Plug-in? Troi Dialog Plug-in is a very powerful tool for displaying all sorts of dialogs in FileMaker Pro 11. The text of the dialog and of the buttons can be created dynamically by using a calculation. All from within FileMaker you can: - show an input dialog to let a user input data in up to 15 fields and up to 4 buttons - choose these input fields to be any of the following: simple text, password field, popup list or check box - show a list dialog or very big text dialog - show temporary flash screens - show a progress bar for lengthy operations - add a standard icon or your own custom icons, now also with transparent PNGs - present slideshow of images and movies fullscreen What is new in version 5.5? Troi Dialog Plug-in 5.5 is an update for FileMaker Pro 11. It has these fixes and new features: - Made compatible with FileMaker Pro 11. - Added compatibility with Windows 7. - (Mac OS X) IconControl: Added support for PNG image format, including support for transparency in the icon. - (Mac OS X) Implemented to Cocoa version of Progress dialog. - (Mac OS X) Implemented to Cocoa version of InputDialog dialog. - Several smaller bug fixes and further improvements. Suggested uses - give your users better and flexible feedback - show quick instructions without the user having to dismiss the dialog - build multi-language systems more easily - make your solutions look more professional by using your own icons and title bars in dialogs - control the way users type in data: you can, for example, let them type more than 10 and less than 40 characters - show a slideshow of images selected from a found set, for example all images with water as a keyword - measure finishing times in a race - measure with accuracy the efficiency of 2 differently implemented scripts. All these features also work in a runtime solution. We invite you to test drive the new functions and see what you can do with it! Pricing & availability A fully functional demo version of Troi Dialog Plug-in 5.5 is available for downloading at Troi's web site at: . Troi Dialog Plug-in 5.5 works with FileMaker Pro 9, 10 and 11. The plug-in can also be used with runtimes from FileMaker Pro Advanced 9, 10 or FileMaker Pro Advanced 11. The plug-in is available for Mac OS X and Windows. On Mac OS X the plug-in runs in Mac OS X 10.5.7 or higher. The plug-in also runs on Windows Vista or Windows 7. QuickTime 7 or later is needed for the Dial_PresentImage() function. Licenses cost US$ 59 per user. Details on developer licenses and multi-user packs can be found on our web site. You can order licenses from our web site. Upgrade information Users who bought a license for Troi Dialog Plug-in on or after February 1st, 2008 are entitled to a free upgrade. We will email these registered users a new registration string. Upgrades from licenses bought before February 1st, 2008 are available from US$ 29 per user. You can order upgrades from our web site. FileMaker Pro 11 compatibility and other Troi Plug-ins As for our other plug-ins' compatibility we have good news: in our preliminary testing we have found no major issues with our current plug-ins. We are continuing our testing and plan to release updates of our plug-ins for FileMaker Pro 11 to fix minor and cosmetic issues. You can find more information on our FileMaker Pro 11 compatibility page, here: http://www.troi.com/filemaker_11.html About Troi Automatisering Troi Automatisering is leading developer of cross platform FileMaker Pro plug-ins and winner of the FileMaker Pro Excellence Award 2001. For more information, visit our web site at: . Contact information D. Budding Troi Automatisering Boliviastraat 11 2408 MX Alphen aan den Rijn The Netherlands Telephone: +31-172-426606 Newsroom: Quote Link naar reactie
