[ANN] Troi Dialog Plug-in 5.5.3 for FileMaker Pro 11
Troi Automatisering releases Troi Dialog Plug-in 5.5.3 for FileMaker Pro 11
Updated dialog plug-in for FileMaker Pro 11 improves on bigger icon support.
Alphen aan den Rijn, The Netherlands, June 29th, 2010--Troi Automatisering today announced the immediate availability of Troi Dialog Plug-in 5.5.3 for FileMaker Pro 11.
Troi Dialog Plug-in is a very powerful tool for displaying all sorts of dialogs in FileMaker Pro 11. The text of the dialog and of the buttons can be created dynamically by using a calculation. All from within FileMaker you can:
- show an input dialog to let a user input data in up to 15 fields and up to 4 buttons
- show a list dialog or very big text dialog
- add a standard icon or your own custom icons, now also with transparent PNGs
- present a slideshow of images and movies fullscreen
What is new in version 5.5.3?
Troi Dialog Plug-in 5.5.3 is a maintenance release, but also adds a few enhancements:
- Added a switch to the Dial_IconControl function: -DefaultIconSize=48. This will make it the default to show all subsequent icons at 48x48, without the need to set it for each dialog function call.
- Added new switch to Dial_Version: -UnregisterPlugin. This will remove the registration data. The plug-in will be in a unregistered state after this.
- (Windows) Improved a problem in the scaling of custom icons: if the width differs from the height the icon will now be scaled proportionally.
- Fixed a problem where in some cases a spinning beachball cursor would be shown instead of the arrow cursor.
- Made small tweaks to example files.
Suggested uses
- show a slideshow of images selected from a found set, for example all images with water as a keyword
- measure time like for a race or the efficiency of 2 differently implemented scripts.
All these features also work in a runtime solution. We invite you to test drive the new functions and see what you can do with it!
Pricing & availability
A fully functional demo version of Troi Dialog Plug-in 5.5.3 is available for downloading at Troi's web site at: .
Troi Dialog Plug-in 5.5.3 works with FileMaker Pro 9, 10 and 11. The plug-in can also be used with runtimes from FileMaker Pro Advanced 9, 10 or FileMaker Pro Advanced 11. The plug-in is available for Mac OS X and Windows.
On Mac OS X the plug-in runs in Mac OS X 10.5.7 or higher. The plug-in also runs on Windows Vista or Windows 7. QuickTime 7 or later is needed for the Dial_PresentImage() function.
Licenses cost US$ 59 per user. Details on developer licenses and multi-user packs can be found on our web site. You can order licenses from our web site.
Users who bought a license for Troi Dialog Plug-in on or after February 1st, 2008 are entitled to a free upgrade. We have emailed these registered users a new registration string.
Upgrades from licenses bought before February 1st, 2008 are available from US$ 29 per user. You can order upgrades from our web site.
D. Budding
Boliviastraat 11
2408 MX Alphen aan den Rijn, The Netherlands
Telephone: +31-172-426606
