Diana Budding Geplaatst: 24 oktober 2013 Delen Geplaatst: 24 oktober 2013 Troi Automatisering releases Troi Activator Plug-in 3.5.1 for FileMaker Pro 12 Updated Activator Plug-in for FileMaker Pro 12 adds compatibility with Mac OS X 10.9 Mavericks. October 24th, 2013, Alphen aan den Rijn, The Netherlands--Troi Automatisering today announced the availability of Troi Activator Plug-in 3.5.1 for FileMaker Pro 12. What is Troi Activator Plug-in? Troi Activator Plug-in is a very powerful tool for triggering scripts across the network, even over the Internet. All from within FileMaker you can: - trigger a FileMaker script on a different client computer - trigger a FileMaker script over the Internet - run a script and send data to a different FileMaker application, all in the background - use the built-in security to prevent unauthorized triggering - send a number (e.g. a record ID) and a long text with the trigger - start and stop listening for remote trigger messages with one script step Apart from remote triggering you can also trigger scripts on the same computer: - run a script from any FileMaker calculation, for example a tooltip calculation - trigger a script on a specified date and time - schedule events which trigger any script you want - trigger a script after exiting a field - validate fields with a custom script suited to your specific validation needs What is new? Troi Activator Plug-in 3.5.1 is a maintenance release and fixes a bug that would prevent the plug-in from loading under OS X 10.9 (Mavericks). Compatibility of Troi Plug-ins with Mavericks On 22nd October Apple released OS X 10.9 Mavericks. The testing of our plug-ins with Mavericks is ongoing. For the moment we can report that all of our plug-ins are running fine. We have created a Mavericks web page which shows which versions of our plug-ins are compatible. We are continuing to work with Mavericks and if we find any issues we will provide more detailed information there: http://www.troi.com/support/mavericks.html'>http://www.troi.com/support/mavericks.html Pricing & Availability A fully functional demo version of Troi Activator Plug-in 3.5.1 is available for downloading at Troi's Web site at: http://www.troi.com/software/activatorplugin.html Troi Activator Plug-in 3.5.1 works with FileMaker Pro 10, 11 and 12. The plug-in can also be used with runtimes from FileMaker Pro Advanced 10, 11 and 12. The plug-in is available for Mac OS X 10.5.7 or higher and Windows XP, Windows Vista, Windows 7, Windows 8 and Windows 8.1. Licenses cost US$ 89 per user. Details on developer licenses and multi-user discounts can be found on our web site. You can order licenses from our web site. FileMaker Server requirements Troi Activator Plug-in 3.5.1 also works with FileMaker Server 10, 11 or 12 as a server-side plug-in and as a plug-in used by the web publishing engine. To use this, you need to purchase a special cross-platform Server/Web license which costs US$ 299. We have prepared extensive information on how to install and use Troi Plug-ins server-side and web-side on this web page: http://www.troi.com/support/filemaker-server-side-plug-ins.html Upgrade information The 3.5.1 version works with the 3.5 version of the registration. If you bought a license for a pre-3.5 version on or after March 1st, 2012 the upgrade is FREE! Eligible users have been sent a new registration string in March 2013. If you bought a license before March 1st, 2012 you will need to buy an upgrade to use the 3.5.1 version. Upgrades are available from US$ 39 per user. Upgrade prices for other licenses can be found on our web site. You can order upgrades from our web site. About QuickTrans for iPhone, iPod Touch and iPad QuickTrans is our iOS app designed to make sending images a snap. After you configure the app once, you can take one or more photos and upload them without any extra steps. QuickTrans is designed to work in tandem with Troi Activator Plug-in 3.x. More information can be found here: http://www.troi.com/quicktrans.html About Troi Automatisering Troi Automatisering is leading developer of cross platform FileMaker Pro plug-ins and winner of the FileMaker Pro Excellence Award 2001. For more information, visit our web site at: http://www.troi.com/ Contact information D. Budding Troi Automatisering Newsroom: http://www.troi.com/news/ Quote Link naar reactie
