I have a question , I'm using the Web viewer to show some custom website and in this website the user need to insert DATES (From and To) manually in 2 fields.
Everything works perfectly fine except that the webviewer is only accepting dates in the american format (MM-DD-YYYY) and if I run the same website in Safari (language set to Dutch) I can insert the dates in European Style.
Is there any way to change the WebKit language from the webviewer ? to accept the european format ...
Installing an European version of FM will work ? ( hopefully that is not the solution )
TiagoCosta17
Hello FMers![:)](//www.clarify.net/applications/core/interface/js/spacer.png)
Thanks a lot in Advance for your help
Tiago
Link naar reactie
5 antwoorden op deze vraag
